Help with bundle
Well that depends on what games you play so if your happy at 1080p then a 27" can be had for £130 , £230 will get you 27" 2560x1440 and £300 will get you 27" 3840x2160 4k.
like the sound of that 4k i play bf4 and will be playing bf1 when it comes out you think my 980ti amp extreme will will be fine with 4k ?
A 1440p would be easier to drive with a 980 ti. If you are going 4K then you would have to lower settings in some games to get the desired frame rates.
The review of the MSI GTX 980 ti below gives you an idea of frame rates for different resolutions.
https://www.techpowerup.com/reviews/MSI/GTX_980_Ti_Gaming/
well guys i went for the 4K and am happy so far with the way its going. my only small prob is coming back to 60hz from 120hz . but the picture quality in game makes up for a bit of that loss as i was 1080p
