18 Mar 2013 at 23:53 #21 Terrier_Jimlad Terrier_Jimlad Soldato Joined 4 Nov 2006 Posts 2,752 Location Yorkshire 30 mins tops
19 Mar 2013 at 00:05 #22 Belloni Belloni Soldato OP Joined 17 Feb 2009 Posts 3,001 Terrier_Jimlad said: 30 mins tops Click to expand... It's going to take longer then that it seems, thanks anyway though
19 Mar 2013 at 00:55 #23 Belloni Belloni Soldato OP Joined 17 Feb 2009 Posts 3,001 I've got it into movieplus 5 as AVI, but the FPS is very low?! Why is this?! I used Freemake convert.
19 Mar 2013 at 07:26 #24 SexyGreyFox SexyGreyFox Man of Honour Joined 29 Mar 2003 Posts 57,643 Location Stoke on Trent Try Freemake Video Convertor. I now use it for all my simple conversion and cutting needs.
19 Mar 2013 at 10:23 #25 bledd bledd Don Joined 21 Oct 2002 Posts 46,836 Location Parts Unknown If you have it as an AVI file Open in virtualdub Find the start of the bit you want to remove, press Home on the keyboard Find the end of the cut, press End on keyboard Press Delete on keyboard Save as AVI Now compress it with whatever tool you're using
27 Mar 2013 at 03:06 #26 lemoon lemoon Associate Joined 12 Nov 2010 Posts 182 Hmm, I think you could get a AVCHD Converter, recently got an ifunia avchd converter's promo code for my MB, and its have Windows version.
