help with cs:s config
29 Apr 2006
hi guys
everytime i go into the options menu and click 'ok', my corosshair size is changing, how can i make sure all the settings are saved in the config file? do i need to load it afterwards? i am kinda new so any help would be appreciated, as well if there are any commands that are useful please let me know. (how can i make the boddys dissapear for example?).
cheers
I get exactly the same thing mate, I know I could make it read only but then if I change a setting it won't get saved etc :(
Dead bodies are handy to keep on though, helps tell where campers/enemies could be etc etc etc etc :p
Dont know if this applys to CSS but in Day of Defeat, to change the crosshair you go into the console and type.
cl_xhair 3
JT
cl_crosshair 1200 is default as far as I know. Change it to any where between 1800 and 2400 and add it to your autoexec.cfg file.
-Dev
1200 is default small setting.
For css settings you better off writing/editing your config then write protecting it or backing up a copy some where else. Makes life easyer
the default cl_crosshairscale setting depends on what resolution the game is running at. some will be 800, 1200 etc .... put cl_crosshairscale 8000 in console for a very small crosshair, make sure its a colour you can see and practice practice practice, headshots will come out of nowhere!! ;)
make a file called autoexec.cfg and put it in your cfg folder
mine looks like this
cl_downloadfilter "nosounds" (gets rid of annoying quake sounds if you dont like them)
cl_crosshairscale 1601 (size of crosshair - mine is pretty small)
hud_saytext_time 4 (how long each line appears in the chatbox)
hud_deathnotice_time 4 (how long info about someone being killed appears in the top right)
voice_enable 1 (lets me hear ppl's mics. sometimes i don't want to)
cl_radaralpha 1 (minimises the gaydar so it doesnt peepee me off)
net_graph 0 (hides fps info etc)
rate 25000
cl_cmdrate 101
cl_updaterate 101
Scam said:
Yes, because changing your crosshair size and colour will surely improve your aim..
Yes.
