Help with Exchange 2003
11 Aug 2004
Perth, Western Australia
I'm trying to reply to email that I have with Exchange 2003 but when logged in remotely using Webmail I can't reply to email. Think it's got something to do with how security is set up on my Vista Home Premium machine because the box where you are supposed to write the body of the message is just blued out and it does'nt let me type there. ANy body any pointers?
Have you tried with an alternate browser? I would suspect ie7
EDIT actually wasn't vista + ie7 incompatible with owa? i'm sure there is a patch you need to install to resolve this.
Thanks guys, I downloaded the recommended update but after going through the motions I got an error saying that I don't have enough storage and the installation ended unsuccesfully????
Its probably getting paranoid about disk space on the partition where your Exchange files are located. Sort this out and it should be fine.
Hmmm....I have 174Gb free.
Never mind I'm using Firefox as suggested and its working perfectly.
But in Firefox you get the Reach client as opposed to Rich client don't you? Without all the nice little context menu's and so on.
I suppose if it works for you then it works...
I'd be keen to get to the bottom of the patch issue though.
