eXSBass said:But off course if you want to spend money try some underfloor heating with marble![]()
VIRII said:I went with laminate as young families pretty much wreck everything anyway and it is far less grief than carpet.
Defcon5 said:With laminate once its worn it needs to be replaced, but with real wood you can sand it down as many as 5 times so it could end up lasting 5 times longer than laminate flooring
schnipps said:The only reason people laminate instead of real wood is £, getting real wood flooring is going to cost a heck of a lot more than laminate, so if money is no object then why would you laminate? i certainly wouldnt. Descent laminate is about 25-30 quid a pack, i wouldnt go cheaper then £20 per pack and ive seen real wood stuff for nearly £100 per pack.
Bear said:I got some real hard wood flooring that is a 7mm slice of wood bonded onto a ply base which fits together like laminate. Got some real cherry hardwood, looks great with all the grain and seems be be hard wearing for the three years its been down.
