Help with getting a new processor
23 Mar 2011
Devon
Hi
I currently have an amd athlon x4 3ghz.
I thinking about changing to an intel i5 2500k sandybridge or amd phenom II x6
Which would be the best option for gaming ??
Thanks
Why don't you stick with your current processor??
An Athlon II X4 at around 3.2GHZ is around the speed as a Q9400 for running games.
What motherboard and PSU do you have BTW??
If you want a boost in gaming, getting a Phenom II X4 and then selling your Athlon II X4 would probably be the best bang-for-buck option.
I dont think you would see much gaming benefit by upgrading. If you do upgrade then I would stick with AMD because then you can keep your motherboard.
I have a gigabyte motherboard and a 700w ccivo power suPply. Thanks for the advice, think I may just stick with the athlon then. Or I may upgrade my graphics card or get some more ram
yeah i know it needs changing :/ it really is crap. least i know now not to buy a power supply on the cheap.
It a mistake lots of people make trying to save money but a good psu will do multiple upgrades to your rig. Can you not just overclock the chip you have to gain more fps ?? Get a better cooler if your still using the stock one.
I won't be making that mistake again, I did overclock my CPU yesterday to 3.3ghz and its made a slight difference. I'll put it up a bit more after I get a better cooler. I'll get it after I get an xfx power supply
Keep your Athlon and wait a few more months, As new tech is out.
I was going to get a Intel Sandy last week but since the bulldozer from AMD is out in a few months (I hope it's worth waiting for) I mite as well wait see what it brings to the table.
