help with LAMP mainly MySQL
19 Jul 2006
you shouldn't need to specify the host if your MySQL system is installed locally. Depending on how you installed it, you'll need
> mysql -p
(which will take your username as who you are logged in on as, use whoami at the command line to check this)
