Help with new build
I think i come to a final parts list thanks to every here but still open to any opions
Corsair Vengeance RGB PRO Black 64GB 3200 MHz DDR4 Quad Channel Memory Kit
Corsair 275R Airflow Tempered Glass White Mid Tower PC Gaming Case
AMD Ryzen Threadripper 3960X Gen3 24 Core TRX4 CPU/Processor
ASUS AMD Threadripper PRIME TRX40-PRO PCIe 4.0 ATX Motherboard
Corsair MP400 2TB M.2 PCIe NVMe SSD/Solid State Drive
Corsair White LL120 RGB 120mm Dual Light Loop 1 Fan Expansion Pack
Corsair RM850 850 Watt 80+ Gold Fully Modular PSU/Power Supply 2020 Update
Corsair 360mm H150i ELITE CAPELLIX RGB Intel/AMD CPU Liquid Cooler (this one doesn't need the extra bracket)
EVGA NVIDIA GeForce RTX 3080 10GB XC3 GAMING Ampere Graphics Card
Well, more/less the same but with one or two tweaks (namely M.2 SSD and to the case that @mickyflinn mentioned). Please note that I have not included the GPU as it is cuirrently not available:
My basket at Overclockers UK:
Total: £2,756.80 (includes shipping: £0.00)
I could be wrong here, but I think the extra Corsair fans need a Corsair controller? (Part of the reason why I haven't gone for them in my current rig)​
those read writes seem a bit low on the WD
- Sequential Read up to (MB/s): 560
- Sequential Write up to (MB/s): 530
Corsair Link also works with Asus board to "better" sync your RGB colours (my Asus board works with it anyway. Needs Asus Aura install for it to work but doesn't control the ARGB header annoyingly). If you want I can post some screenies to show you?
Screenshot of iCUE software for Corsair to show that it doesn't show the ARGB headers: https://photos.app.goo.gl/4r4PrqQ2KVFuRuXm8
good luck buying 3080 :)
if you want to build it now you will probably need some weaker gpu for now.. as threadripper cpu's to not have an integrated gpu
