help with next weeks build
23 Nov 2009
North Leicestershire
my phenom rig is coming next week.
i was gonna build the mobo,ram,cpu,and baram outside the case would the best was to do this be on my boogie bug gaming mat and a inside out anti static bag?
yea make sure you discharge yourself of static by keeping your foot on a radiator if your paranoid
i got a wrist strap a while back when i took the 939 build out the micro atx case and put it in the haf 932.
i'm just s*****g myself that it don't post or something after it's been built lol.
saying that i need to pick up a cheap sata dvd drive before wednesday as i hear the ud-5 FXTA can be a pig to get to work with IDE drive
any suggestions for a cheap yet good sata dvd drive
they are all around the same price , on my next build im just going to use the microsoft tool to put a bootable version of windows 7 onto a 4gb usb stick and boot from that :)
The ThermoLab Baram is a bit of a beast to stick on before you installed your mobo!
I installed mine once the motherboard was screwed down in the case . . . . very easy when running passive in the Antec 300 but I had some trouble getting the fan clips installed once I added the fan to help get the bigger overclocks! . . . . as you can see in the pic below the lower right hand corner is a bit hard to access . . .
I'm waiting for an adapter from Thermolab so I can swivel the heatsink so it faces up to take advantage of the 140mm roof fan! :D
If i build it outside the case whats the best way to pick the mobo up to put it inside.
i do have a HAF 932 with a cutout in the mobo tray for quick changing Heat sinks you think i should install it in the case.
also my haf has a 230mm roof fan maybe i should get an adapter aswell, do you have their contact details so i can order one?
Pick it up carefully holding the edges, try and get your hand under the board asap to give it support otherwise it will flexing like a flexy thing! :p
Probably easier to install the Baram once the board is secured but either way will suffice! :cool:
i'll have a look at doing it with mobo inside the case (at least there will be more support for it)
i imagine it weighs a fair bit not gonna go doing damage to the socket is it :eek:
It's probably easier doing in that way, the only fiddly butmay be getting the fan clips attached if your case is a bit smaller . . .
Of course you may not need a fan at all! ;)
Nah, you'd be suprised, it's a work of art and not too heavy. The base is a thing of beauty, perfectly flat and a mirror finish! :cool:
