Help with overclock
28 Dec 2010
Trying to oc my i7 930 to 3.8Ghz then ran Linx and it stopped due to an error 4mins in. How do i know what caused the error and could someone maybe help me tweak the below settings, Thanks.
My Specs are:-
- Intel i7 2.8Ghz @ 3.8Ghz
- 6GB Ram
- Asus P6TD
- Ati 5970
- Windows 7 64bit
- Titan Fenrir Cooler
OVerclock Settings
Ai Overclock Tuner.....................[Manual]
CPU Ratio Setting......................[21.0]
Intel(r) SpeedStep(tm) Tech............[Disabled]
Xtreme Phase Full Power Mode...........[Enabled]
BCLK Frequency.........................[181]
PCIE Frequency.........................[100]
DRAM Frequency.........................[DDR3-1451MHz]
UCLK Frequency.........................[2903MHz]
QPI Link Data Rate.....................[Auto]
CPU Voltage Control....................[Manual]
CPU Voltage............................[1.23125]
CPU PLL Voltage........................[1.80]
QPI/DRAM Core Voltage..................[1.22500]
IOH Voltage............................[1.14]
IOH PCIE Voltage.......................[1.50]
ICH Voltage............................[1.20]
ICH PCIE Voltage.......................[1.50]
DRAM Bus Voltage.......................[1.64]
DRAM DATA REF Voltage on CHA...........[Auto]
DRAM CTRL REF Voltage on CHA...........[Auto]
DRAM DATA REF Voltage on CHB...........[Auto]
DRAM CTRL REF Voltage on CHB...........[Auto]
DRAM DATA REF Voltage on CHC...........[Auto]
DRAM CTRL REF Voltage on CHC...........[Auto]
Load-Line Calibration..................[Enabled]
CPU Differential Amplitude.............[800mV]
CPU Clock Skew.........................[Delay 300ps]
CPU Spread Spectrum....................[Disabled]
IOH Clock Skew.........................[Auto]
PCIE Spread Spectrum...................[Disabled]
C1E Support............................[Disabled]
Hardware Prefetcher....................[Enabled]
Adjacent Cache Line Prefetch...........[Enabled]
Intel(r) Virtualization Tech...........[Disabled]
CPU TM Function........................[Enabled]
Execute Disable Bit....................[Enabled]
Intel(r) HT Technology.................[Enabled]
Active Processor Cores.................[All]
A20M...................................[Disabled]
Intel(r) C-STATE Tech..................[Disabled]
You could probably do with some more core voltage.
Take the base clock back down to a level where it's stable, then increase in increments of 5, testing for stability each time. When it becomes unstable give it a little bit more core voltage, and try again. Repeat as necessary.
Good stuff. Make sure you keep an eye on temperatures when increasing the voltage. A little extra can make things significantly hotter.
yup totally fine, your ok up to the mid 80's so don't worry. Keep it running for a good bit longer though, the most annoying thing about overclocking is the time it takes to test for stability lol.
If using Linx set it to all memory, and 20 times to run.. Thats generally a good indication the cpu is fine. Now as before if an error pops up, or crashes, generally just notch up vcore/qpi again, and restart testing.
Prime (blend test) is best to check that cpu/mobo/memory are all stable, 8 hours is the general consensus for full stablilty. So yeh an over night run of that is good to do.
Well it.passed 20 runs of LinX without fail so i'll try it using all the memory then give Prime95 a good run and see how it all goes! If they dont go over 70 do you think i should try to hit 3.9Ghz or 4.0Ghz+
Testing mine again yesterday with LinX all memory, failing on the second test, strangely though its passed 20 runs of LinX before.
Previous run
Yup your good to go for 4ghz no probs, but bare in mind that the vcore/Qpi may need to be raised quite a bit, so temps may and most probably will hit 70+.
