help with overclock
20 Jun 2012
hi all im looking to overclock my cpu
i7 2600k
mobo p8z68/gen3
power supply 750 watt
cooler corsair h70
im new to this do not have a clue what to do but want to oc for more power for gaming any help plz?
Firstly, you should have posted in Overclocking and Cooling subforum to start with.
Secondly, there is a handy guide on that sub forum here.
With Sandy, it is easy to overclock. I would just start by raising the Multiplier in the BIOS to x40, seeing how stable it is as detailed in the guide, then moving the Vcore voltage up if it isn't and moving on from there. Any issues you can post back and get some more help from here :)
so then using prime 95 for half hour my results are
torture test completed 0 errors 0 warnings
real temp
maximum was 81
but i have asus ai suite and said warning 72 cpu centigrade is this normal?
