Hi all! My computer keeps getting a bsod and is very slow on start up. I don't know why, I have looked through forums to help with my bios settings but It's gone so far now that I decided I will post mine and see if some nice people will tell me what I need to fix
I have
I5 2500k
Asus p8p67 pro motherboard
corsair CMX4GX3M2A1600C9 ram
His 6950 graphics card
My bios settings are:
ai oc tuner manual
bclk 100.0
turbo ratio by all cores; 46
pll overvoltage; enabled
mem freq; 1600mhz
epu power saving; disabled
load line cal: extreme
vrm freq: auto
phase control: extreme
duty control:extreme
cpu current capability: 120%
cpu vol: manual @1.35
dram vol: 1.65
vccsa: auto
vccio: auto
pch vol: auto
cpu pll vol: 1.80
cpu config:
cpu ratio:33
limit cpuid max:disabled
execute disable bit: enabled
intel virtualization technology: enabled
speed step: enabled
turbo mode: enabled
cpu cie: auto
c3 report: auto
c6 report: auto
dram timings
9
9
9
24
2
the rest are auto
I really appreciate any help I get. Thanks
I have
I5 2500k
ai oc tuner manual
bclk 100.0
mem freq; 1600mhz
vrm freq: auto
dram vol: 1.65
vccsa: auto
vccio: auto
pch vol: auto
cpu pll vol: 1.80
cpu config:
cpu ratio:33
speed step: enabled
turbo mode: enabled
cpu cie: auto
c3 report: auto
c6 report: auto
dram timings
9
9
9
24
2
the rest are auto
