Help with spec and build
I'm afraid it won't be enough.
Cutting corners to much is a really bad idea.
I tried that once and ended up badly, so better save up and buy proper hardware when you can afford it.
Guys above gave you good options.
Haswell integrated gpu is good enough to play some games - I played guildwars 2 on mine on medium settings.
Going to start ordering parts from Danny's Intel spec I've found the motherboard for £40 and was wondering if the avexi core ram is a good price on overclockers?
Also going to get the i5-4670k
I could get this?. http://www.overclockers.co.uk/showproduct.php?prodid=BU-005-MS
With i5-4670k this comes too £257 (comes with free cooler)
TeamGroup Vulcan Orange DDR3 (2x4Gb 2400mhz) £55.99
Was looking at the avexir core blue series is it worth 59.99? The LEDs do look nice :D
Also going with a cooler master K-280 £33
And a Corsair CP-9020077-UK Builder Series 650W CS650M ATX/EPS Plus Gold Power Supply Unit for £63
And a Samsung 24x retail SATA £13.06
