Help with upgrade advice
27 Nov 2011
Edinburgh, UK
Current Basic spec is I7 2600 3.4GHz / XFX PRO 850
Asus P8H61-M LE/USB3 / 2gb Nvidia 560 TI Twin Frozr ii
8gb Corsair XMS3 / Corsair 600T White
Basically I built the pc in 2011 iirc so is due an upgrade, still works fine just doesn't play modern stuff on any decent settings
I have been looking into the ryzen stuff quite a bit and also looking at a rx 580 as well coupled with some better ram
My power supply,
hard drives, case are all sound so nothing wrong with them
I use my 55 inch 4k tv for gaming as I set the PC up in the living room now
Would the ryzen 5/7 with the rx 580 be a good upgrade? They seem really good spec for the price, I only game a couple of times a week, so occasional photoshop so doesn't need to be anything crazy, just enough to run the newer games on higher settings etc
Any advice would be great
You would see an increase with i7 8700k .. but at the moment, you'll see that performance at a high cost ! Coffeelake is aimed at shifting over 1st/2nd gens owners as they'll the most performance increase . But your talking some heavy cash ! £700+ ...
As above , slap in a GPU first and have a look at the performance your getting in your games say to a system with the same card on a new Chip such as coffeelake/Ryzen .
Check to see how your CPU and GPU usage is with the new GPU , should indicate easily if you do need to refresh your system .
For a Ryzen 1600+8GB ram plus Mobo your looking £439 odd , which is a damn site cheaper then Intel's
Yeah gonna have a look at black Friday deals
I have an ssd already so that's fine, just a 1080 is well out of my budget, I don't game enough to justify that kinda cost on a card
Don't worry. You'll still be able to game at 4K with a GTX 1060, but you'll have to settle for medium details.
