Help with upgrade
8 May 2008
Sunny Devon
Hi guys,
I'm in need of some advice for a long-awaited upgrade for my rig. I'm totally out of the loop hardware wise so any help would be much appreciated.
I'm looking to spend around £600, to include a new monitor (ideally 24").
At the moment I'm running a Phenom II X4 (which must be about 6 years old) which has done me proud but is really starting to show its age.
I upgraded my gfx with an R9 270X 2gb last year so I plan to keep that.
I upgraded my PSU at the time too, so I'm thinking all I need is a new CPU / motherboard / memory? Maybe an SSD too.
I was looking at one of the DEFCON 3s skylake bundles for £450ish, depending on cooler. Would that be a good way to go? Or are the AMD setups still good bang for buck?
I just use the machine for games and I play quite a bit of CS GO so I was looking at a 144Hz monitor. The AOC G2460FQ looks pretty good value?
Thanks very much in advance.
skylake be good, but if that 270x sports freesync then this monitor would be more ideal if you was set on AOC.
My basket at Overclockers UK:
Total: £609.67
(includes shipping: £11.70)
