Help with watercooling setup
Ok guys slight change of plan, I now have 2 X GTX 480 in SLI!! So I will need to change my water plans, any suggestions as to what I might need to change, apart from the EK FC GTX blocks I know, but some people are saying I need to have a separate rad and loop for the cpu? to maintain its 4ghz overclock? any help would be appreciated, cheers.
I would say that a Therm 120.3 on its own would cope quite adequately with 480SLI and an i7 @4ghz.
I managed to cool a QX9650 @4ghz, 2 x GTX260, NB, SB and 2 x mosfets without difficulty on a Therm 120.3 with Yate Loon fans. Yes I know the 480s run hot but I find people tend to overestimate the heat output of their components and to underestimnate the cooling potential of their radiators.
Just make sure you get a top quality pump such as a Laing 18w or a D5.
Good cos if it needs two loops things can get a bit cramped in these cases.
I dunno, I think a 120.3 rad will be cutting it close, you probably won't be able to overclock anything more than it is
That's great advice, so far I am looking at the following, please can you tell me which other bits I would need?
Also this is my current system:
You will also need 10 x barbs or compression fittings (I prefer compressions). Your res may well come with EK barbs pre-supplied as may the gpu blocks.
A quality 120.3 radiator plus 3 120mm fans
I'd advise getting more than a metre of tubing, get 3/4 metres, just in case you want to experiment or make some mistakes. Its cheap so why not?
I would also advise getting an EK top fitted on that D5 pump. Google the following: EK-D5 X-TOP - Acetal G1/4 Rev.2
Edit/ Another thing to bear in mind is that Therm rads use barbs with non-standard thread sizes, 3/8" bspp I think so you'll need two of them and possibly 8 x g1/4"
Ooh, going for a 120.3 with 2x480 and i7? I'd be interested to know how this works out! I wouldn't be 100% on you reaching you 4GHz clock back, and you defo wont be able to overclock the GPU's. I don't know anyone who's done that all off one 120.3!
I personally (in an ideal world) would go for a 120.3 for the GPU's and a 120.2 for the CPU in separate loops. Although to find a case for all that isn't the easiest and it starts getting a bit expensive!
One piece of adivce I would give, put the CPU first in the loop so it gets the coolest water possible!
on the note of the fittings, if you can afford to pay a bit(read a lot) extra it might be worth getting shutoff fittings
I suppose another way of doing it would be to get a corsair H50 for the cpu, and then have the 480's on a loop all of their own?
Or leave the CPU on air only and just water cool the 480s? they are the hottest and noisiest things in the case?
The 480's at stock will most probably be noisier (read much noisier) than the rest of the setup. I can't say what noise your current CPU cooler shoves out, but 480's in sli have been benched to top 65 db (it was 67 exactly I think). In sli they ran at a toasty 98'c under full load, if there is one thing you want to wc (well two I guess), it is these!
Yeah I think that'd be the way to go, so what exactly will I need for just watercooling the GPUs?
Its a bad idea to only put the GPUs on a loop. I would still argue that a Thermochill PA120.3 can easily cool 2 x 480 and an overclocked i7 cpu. I don't see any reason to build two separate loops for the CPU and GPUs.
OK well I suppose I can try it out and see what happens. worst scenario is that I would have to add something else, like another loop. So just a bit more reading before ordering really as I don't want to order something by mistake that I don't need!
I would not recommend running 2x 480's and an i7 @ 4+ in one loop with only the 1 120.3 rad. I run my i7 and northbridge on a 120.2 and my 4870x2 and mossfets on a sep loop on a 120.3 both loops delta runs at about 10deg above room temp.
edit: make sure you put a drain point in your loop! you will kick yourself later if you don't.
I have recently watercooled my SLI 480's, it has made a huge difference to the noise of my machine (plus 920core/1100mem is a brucie bonus). I used the following parts for the GPU loop:
Thermochill PA120.3
XSPC Laing DDC 200ml Reservoir Pump Top
Laing DDC-1+ Ultra 18W
EK480 blocks
(plus various fittings, tubing and fans)
That little lots keeps my overclocked 480's nice and cool, I have never seen the temps go above 63c (and that was with with furmark). Given the heat I can feel coming from the RAD when the cards are under full load, I would be very wary about adding an i7 into the loop.
Thermochill PA120.3
EK480 blocks
I really like the sound of your setup, what fittings, tubing and fans did you use? I think I am going to go for the same and try and overclock my 480's after.
Just standard 1/2" barbs with Masterkleer 7/16" Tubing. I used a dedicated SLI connector between the cards ( http://www.overclockers.co.uk/showproduct.php?prodid=WC-183-OK&groupid=962&catid=1529&subcat=1747 ). For the fans, I picked up 3 Scythe S-Flex 1600RPM jobbies. I have a less than clear pic of the inside of my case here: http://homepages.nildram.co.uk/~layte/pics/480-tape-lol.jpg
Thats brilliant help thankyou very much! I notice you have a separate loop for your CPU is that with another Rad?
