Help with watercooling setup
When you fill your loop do not attach the atx lead to the mobo, or power anything else up at all, only the pump via a molex. You use a paperclip or wire or something to bridge the green and any black wire on the main 24 pin cable from the power supply, this effective "arms" the psu. You then use the main switch on the back of the psu two blip power on and off. The blipping is necessary as when you put some water in the res and blip the power on, the water is immediately forced out of the pump and into the rest of the loop. If you don't turn the power off before all the water has left the res then you will be running the pump dry. This is a bad thing. So in order to stop this fill the res, blip on/off, fill a bit more and so on. Never let the res run dry. Eventually there will be enough water in the loop that you can leave it running to full bleed, with occasionaly topping up.
Thanks Bubo, that's great, I found some videos demonstrating what you just said, thanks I will follow it to the letter.
Just a couple of things, do I put the PT nuke in BEFORE I put the water in the reservoir?
Also you said to lean the case to bleed the air from the rad, is that after I have blip filled the loop?
Also once I have filled the loop then I seal the reservoir?
thanks again!
Also as the Rad is going to be on the top of the case, I was wondering is it better to have fans pushing air out of the case across the rad or on the top of the rad pulling air in?
Fans: Normally, in fully water cooled systems the consensus is it is better to have fans drawing air from outside the case through the rad. However, since you still have an air cooled sink on the cpu, I would hazard a guess that the increase in ambient case temps this would cause would not be good for the cpu overclock, so I would have fans pulling out. Best to try both though to be sure.
PT Nuke. It doesn't matter when you put it in, as long as it mixes properly. Just put it in with you first fill. Pay attention to the dosage instructions.
Leaning: Once the lopo is sufficiently filled so water is going round the loop without you having to put more in, yhen you can lean the case about to your hearts content in order to get air out of the nooks and crannies it will collect, as long as you never expose the pump inlet to bare air. As to where air will collect, work on the basis that air left to its own devices will rise, so look at your loop and imagine where a bubble of air would go if it started at any point in the loop, and work out how you need to lean/rotate the case to get it out of that pocket.
Res: Once you've finished the main bleeding, put the plug on and leave it running. Come back a day later and top up if necessary.
Thanks Bubo you're a star! really helpful advice and I think at long last I am ready to start! I have the bits arriving mon & tues, so once I have started I will take a few pics along the way!
Well finally got there!! Also I changed case as I wasn't totally happy with the coolermaster ATCS 840, so i got myself a Corsair Obsidian 800d!
Here are some pics:
I am getting some awesome temps on the cars now, they idle at 31 degrees and after 20 minutes of Kombuster they are at 48 degrees each!!!! and NO annoying hair drier noise!!!
Well chuffed!!!
Thanks to everyone for all your help!!!!
Next I am going to try overclocking them now, let's see what these baby's will do!
My SLI 480's do 920core/1100mem (@1.13v) with a max temp of 62c using Kombuster. (Beating out TriFire setups in the ATI optimised AvP benchmark is nice :p )
Is the pump ok noisewise just sitting on the case bottom there? Or is that not its final resting place?
Did bleeding go ok? I guess it did judging by the temps.
Good effort overall. Cpu next then.
well I can hear it whining a little but I am not sure where I can put it, it's just sitting held in place by the tubing.
Yes the bleeding went well, thanks to your help and suggestions! there were a few nightmate moments with it all, one of them being that when i changed my mobo over to the new case i found 4 transistors rolling round in the bottom of the case!!!! when I looked they have fallen off my mobo! but I have been testing everything and it still seems to be working!! wierd! maybe they belong to a redunant bit of the motherboard, I don't know but it still is working/gaming good.
