Okay seams to be some amssive confusion going on all round so here's the low-down on the latest finds on my ram.
Just spent ages googling the net and found a OCZ tech surports post from an OCZ guy. By the way mine has the V1.1 in the corner. So what timings and volts should i do to get to 1:1. Slackest 1st being what? As you should have picked up by now and guess i have no balls, brains ideals etc etc to do with RAM so please give all pointers you can.
01-20-2006, 09:11 AM #3 RyderOCZ OCZ Support Staff
We are using TCCD and TCC5
v1.1 (Tiny in lower right hand corner of white sticker) on the PC3200 Rev 2, PC4200, and PC4800 Platinum's are TCC5
v1.0 on the same is TCCD.
http://img160.imageshack.us/my.php?i...rev2v116ww.jpg
Close up of my ram
''Just thought someone would like to know as all you know that these sticks got some insane overclocking potential....''
Found on the same forum i pull the above off!
There is also the possibitly that they could be TCCD, i found that 50% of the users/owner of the reviews, forums i looked at took the gutts removed heatspready and it said TCCD yet the white sticker said v1.1. I have no idea what to do. Shame there aint a ram tester that will say as does cpuz for what chips they are
Close up of my ram
