When it comes to 1GB RAM, there are two types of RAM that are the best. The two types are Samsung TCCD and Winbond BH5. Between the two, it is very close in terms of performance when both are completely maxed out.
Timings: The tighter they are, the better performance you get.
FSB/Frequency: The higher this is, the better performance you get.
TCCD will run all the way up to about 300mhz FSB (with very good sticks, most top out about 280mhz) running at loose timings. The loose timings are offset by the fact that the RAM is running at such a high frequency.
BH5 will run up to about 270-5mhz (with very good sticks, 265mhz seems the be the average user topping out). BH5 can run the very tightest timings i.e. best performance throughout its entire frequency range but will not go as high as TCCD.
For this reason, you need to determine what is the max FSB you will be running. As there will be very little difference between 300mhz TCCD vs 250mhz BH5 (due to loose timings TCCD and tight timing BH5).
There are 4 key timings when it comes to RAM.
CAS-tRCD-tRP-tRAS (strictly speaking CAS is tCL). At any given frequency, you want the numbers to be as small as possible for best performance.
This is basically how RAM works.
So, what you need to do is work out what FSB you want, and choose accordingly.
You already have TCC5 which is like a slightly lower quality TCCD RAM. It will work to high FSB but with loose timings. Probably topping out at about 275mhz with loose timings of about 2.5-4-4-7 (average).
