15 Sep 2008 at 22:33 #1 MAXIBOY MAXIBOY Associate Joined 17 Oct 2006 Posts 621 whats the max size of drives on windows xp...please
15 Sep 2008 at 23:10 #2 MAXIBOY MAXIBOY Associate OP Joined 17 Oct 2006 Posts 621 also can you hot swap sata drives please
15 Sep 2008 at 23:30 #3 Major_Disaster Major_Disaster Associate Joined 2 Nov 2007 Posts 488 Think max size is 2TB (some one correct me). Dont think you can hot swap... you are in server territory there.
16 Sep 2008 at 00:18 #4 helmutcheese helmutcheese Permabanned Joined 19 Jun 2007 Posts 10,717 Location InURmama Yes you can HotSwap SATA drives if the Controller supports it (all these days will).
16 Sep 2008 at 08:42 #5 rpstewart rpstewart Man of Honour Joined 11 Mar 2003 Posts 10,704 Location Greenock, Scotland Major_Disaster said: Think max size is 2TB (some one correct me). Click to expand... Yup, maximum size of the physical volume is 2Tb on XP32. You can go larger with Vista, XP64 or the MS Server OSes. EDIT: While you can use > 2Tb volumes on Vista etc the boot volume has to be less than 2Tb due to BIOS restrictions. Last edited: 16 Sep 2008
16 Sep 2008 at 10:35 #6 bledd bledd Don Joined 21 Oct 2002 Posts 46,890 Location Parts Unknown which sata controller do you have? some can't, some can (it'll have a 'safely remove hardware' icon in taskbar if you can )
