Help
2 Jul 2007
Cheshire East
On my advice a friend of mine bought this system from here a month ago.
"Titan Predator" Intel Core i3 530 2.93GHz @ 4.20GHz ATI Edition DDR3 System
From day one he has had problems with his graphics card crashing during gaming. He has a ATI 5830 in it.
He has tried resetting bios to default in case it was an unstable over clock and when he got in touch with OC they said return the graphics card. He recieved a replacement yesterday and it is still crashing as before.
What do you guys suggest he does now....to me it must mean either a PSU , motherboard or memory issue.
He is in the process of running a memory test on each stick to see if it is a memory issue but i dont think he should have to do this
Is he entitled to return this pc for proper testing at no cost to himself, or will he have to pay to get it sent back.
Any suggestions most welcome
Ah, yes. I did nor read the the first part properly, thought it was just the overclocked bundle he bought, not a whole system :)
Did he install the operating system and drivers, possible to uninstall and then re-install the gpu drivers.
He has done a clean install and has all the latest drivers. He tried using 1 stick of memory at a time and still had the same problem.
update......he has put the graphics card in the second pciex slot and has been running ok for an hour........looks like a faulty motherboard
we have checked everything....temps, fans, memory,changed graphics cards, done reinstall of windows twice,tried all newest drivers....the only thing we cant check is psu, we think its either a faulty psu or otherboard....anyone else have an idea what to do
if it playing up then just send the whole back.
it's not worth trying to sort it out if there is a problem and the bundle is still under warranty.
According to the description on the shop site that system comes with a 12 month collect and return warranty so Overclockers should arrange collection at their expense.
