Hi First Ever Build Question
Product Name Qty Price Line Total
Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor - Retail £191.99
(£159.99) £191.99
(£159.99)
Asrock P67 Extreme 6 Intel P67 (Socket 1155) DDR3 Motherboard - (Sandybridge) £159.98
(£133.32) £159.98
(£133.32)
Noctua NH-D14 Dual Radiator CPU Cooler (Socket LGA1366/LGA1156/LGA1155/LGA775/AM2/AM2) £71.48
(£59.57) £71.48
(£59.57)
XFX Pro 650W Core Edition Power Supply £68.99
(£57.49) £68.99
(£57.49)
OCZ Special OPS 4GB (2x2GB) DDR3 PC3-12800C8 1600MHz Dual Channel Kit (OCZ3SOE1600LV4GK) £31.19
(£25.99) £31.19
(£25.99)
Sub Total : £436.36
Shipping cost assumes delivery to UK Mainland with:
DPD Next Day Parcel
(This can be changed during checkout) Shipping : £10.00
VAT is being charged at 20.00% VAT : £89.27
Total : £535.63
Absolutely perfect for you and saves you £65 towards the new gpu.
id get something more like this, for gaming it will blow the 5770 out the water and most other systems for that matter.
i included a blu ray drive because you said it would be one of the uses, the stock i5 2400 will go up against 1156 i7's so its a no brainer at the price it goes for.
also specced a 480, you can easily fit it in the budget and is twice as fast as the 5770, heat shouldnt be an issue as you say the case you have is huge, it should have good air flow.
i5 2400 vs i7 870, 940, 950
5770 vs gtx480
this is just over budget..
Asus GeForce GTX 480 1536MB GDDR5 PCI-Express Graphics Card with Far Cry 2 Asus GeForce GTX 480 1536MB GDDR5 PCI-Express Graphics Card with Far Cry 2 £199.99
(£166.66) £199.99
(£166.66)
Intel Core i5-2400 3.10GHz (Sandybridge) Socket LGA1155 Processor - Retail Intel Core i5-2400 3.10GHz (Sandybridge) Socket LGA1155 Processor - Retail £154.99
(£129.16) £154.99
(£129.16)
Foxconn H67A-S Intel H67 (Socket 1155) DDR3 Micro-ATX Motherboard - (Sandybridge) Foxconn H67A-S Intel H67 (Socket 1155) DDR3 Micro-ATX Motherboard - (Sandybridge) £79.98
(£66.65) £79.98
(£66.65)
Intel X25-V Value 40GB 2.5" SATA-II Solid State Hard Drive (SSDSA2MP040G2R5) Intel X25-V Value 40GB 2.5" SATA-II Solid State Hard Drive (SSDSA2MP040G2R5) £71.99
(£59.99) £71.99
(£59.99)
XFX Pro 650W Core Edition Power Supply XFX Pro 650W Core Edition Power Supply £68.99
(£57.49) £68.99
(£57.49)
OCZ Special OPS 4GB (2x2GB) DDR3 PC3-12800C8 1600MHz Dual Channel Kit (OCZ3SOE1600LV4GK) OCZ Special OPS 4GB (2x2GB) DDR3 PC3-12800C8 1600MHz Dual Channel Kit (OCZ3SOE1600LV4GK) £31.19
(£25.99) £31.19
(£25.99)
Sub Total : £505.94
Shipping cost based on delivery to Home, PR8 1JZ with:
FREE SHIPPING (DPD Next Day)
(This can be changed during checkout) Shipping : FREE
VAT is being charged at 20.00% VAT : £101.19
Total : £607.13
Guys he said he wanted to save money for a enw gpu later and in my opinion that is the better to do so he won't have to sacrifice a mobo cpu cooler or better cpu.
(£166.66) £199.99
(£166.66)
(£129.16) £154.99
(£129.16)
(£66.65) £79.98
(£66.65)
(£59.99) £71.99
(£59.99)
(£57.49) £68.99
(£57.49)
(£25.99) £31.19
(£25.99)
Sub Total : £505.94
Total : £607.13
You get free delivery so it would be just over budget for you but to him it will be more expensive as he has to pay for delivery.
thats fair enough, but like i said, if he doesnt intend on overclocking then the build i specced would be better, i have a 2400, 8gb ram 64gb ssd and have used with a 5970, i dont need to overclock my cpu as its not a bottleneck in any game i play.
what gpu would be best to save up for in your opinion? over a gtx 480, 560, 6950 right now?
Why get a D14 when a H50 does the job and the money saved can be used to get a better case?
(edit: searching around I think D14=H50. I'd still go for the H50 just to save space, and plus with the case you linked to I doubt a D14 will fit inside.)
erm i might overclock in the near future but for the time being i am gnna stick with stock outputs, am not that interested in SSDs since they are quite expensive, i've also been told that they can degrade over time.
Yh currently my BD drive is inside a OEM pc atm but when i start i will take out the BD and stick it in my new case.
hey anuraj
Thanks so much for replying, when i was first thinking of building my rig, i was considering the Sandbridge line of cpu, but then i read that the SandyBridge CPU had a limitation which caused problems with SATA so, i drifted away and went back to thinking of buying an i7
Thanks for listing some parts for me, i shall be researching some more on this.
haha
Thanks Again
Can you not just plug your hdd and optical drives into the 6gb/s sata ports and avoid the problem altogether? If so I dont see what the big deal is for custom builders...
it isnt a big deal, it affects 5% of boards and even if your in that 5% port 0 and 1 are unaffected anyway, besides even if you did buy, youd get a shiny new board in a few months if anything did happen.
right so i have decidied to go for the SandBridge since normal x58 are expensive, one question how would i know if a SATA port has degraded (IF i my board falls in that 5%).
Aslo would these mobo fit into my case. if u dont what my case looks like, its on the first page.
