I've flashed the bios to the latest revision. Core voltage is now 1.217v (auto [down from the 1.419v]) but it's not stable in Windows. I've completed frozen 3 times trying to write a reply. Another thing I've noticed is that all cores appear to be running at their boost clock speed all the time (4.4ghz reported in BIOS and by CPU-Z). Is this the intended behaviour or is there something else happening here as well?
Just to give you a little extra information. This build is over 2 years old, I bought on Black Friday 2014 from overclockers. As far as I'm aware, it'll have been running at this voltage since bought :/ I've never had any instability issues, and have never experienced any crashing. The only reason I noticed is because I'd moved the components in to a new case, and on a whim decided to install hwmonitor and cpu-z, and noticed the temperatures on load were high (this was with the stock cooler). I replaced the stock cooler with the Corsair H75, the temperatures are slightly lower (maxed at 85°C) but are still too high
ok so a little update. after resetting to bios defaults and enabling xmp, i managed to run csgo for around 20 minutes without issue, then bf1 for about 10 minutes before it locked up, this time i got a stop code in win10 - CLOCK_WATCHDOG_TIMEOUT, which I believe is related to the CPU. temps during this time weren't very high, playing csgo peaked at around 55°C, bf was warmer, but not massively high at 69°C so it seems overheating isn't an issue.
What are my options at this point? Would I be best off just adjusting the voltage to the CPU in increments from the stock voltage and see if I can get it stable?
ok cpu clock ratio and uncore ratio are now both at 35.
i had a look at the xmp profile and it looks fine, the ram timings are 11-11-11-31 which match up with what's stated on the product page: https://www.overclockers.co.uk/team...hannel-kit-tlaed38g2133hc11adc-my-037-tg.html
Can you download Aida64 from here: http://download.aida64.com/aida64extreme580.exe
Open Aida then go to tools, system stability and run the default stress test for an hour and see if it crashes. If it doesn't crash then maybe the GPU is at fault.
