High End System Build Plan
28 Feb 2013
Birmingham
So over the summer, hopefully, I should be undertaking a big project to build myself a brand new high end rig which should last for years (with future upgrades inevitable) using components bought from OcUK.
Without further ado, here are the current planned specs of the beast:
Case
OcUK Tech Lab - V12 Watercooled Case - Corsair 800D
CPU
Intel Core i7-3930K 3.20GHz (Sandybridge-E) Socket LGA2011 Processor
GPU
EVGA GeForce GTX 680 SC Signature TWO 2048MB GDDR5 PCI-Express Graphics Card
MotherBoard
Asus Rampage IV Extreme Intel X79 (Socket 2011) DDR3 Motherboard
RAM
Corsair Vengeance Black 16GB (2x8GB) DDR3 PC3-14900C9 1866MHz Dual Channel Kit
SSD
Samsung 256GB SSD 840 PRO SATA 6Gb/s Basic
Mechanical HDD
Seagate Barracuda 2TB 7200RPM SATA 6Gb/s 64MB Cache
PSU
Corsair Professional Series AX 860W '80 Plus Platinum' Modular Power Supply
Optical Drive
OcUK 24x DVD±RW SATA ReWriter (Black)
OS
Microsoft Windows 7 Home Premium SP1 64-Bit
Monitor
Dell UltraSharp U2713HM 27" Widescreen LED Monitor - Midnight Grey
Keyboard
Corsair Vengeance K90 Mechanical Gaming Keyboard
Mouse
[Already have a gaming mouse]
Total Cost as of Posting = £3049.99
Yep, that's a lot of money indeed. So, what do people think?
P.S: I did want to go for either the new GeForce Titan or a GTX-690 but that would be another £400-500; and I probably can't afford to go that high as the price is already astronomical.
nice spec, will look at it and see what i can do
what cpu cooler are you going to use? as you cpu doesn't come with one? unless your using your case etc
Alpenföhn K2 Mount Doom CPU Cooler http://www.overclockers.co.uk/showproduct.php?prodid=HS-020-AL would fit and does a great job, quite and very good at cooling
or
Corsair Hydro H100i High Performance Liquid CPU Cooler
http://www.overclockers.co.uk/showproduct.php?prodid=HS-015-CS&groupid=701&catid=2330&subcat=2342
and why go for Nvidia when these are just as quick, if not quicker and a lot cheaper
http://www.overclockers.co.uk/showproduct.php?prodid=GX-097-GI&groupid=701&catid=56&subcat=938
i've also been looking at some bundles for you, something to think about, maybe?
http://www.overclockers.co.uk/showproduct.php?prodid=BU-145-OE&groupid=43&catid=2512&subcat=2519
Do I need a CPU cooler? The watercooled case (V12 Corsair Obsidian 800D) has a CPU waterblock does it not?
Also, well, to admit it, I'm a bit of an NVIDIA fanboy - but for good reason, every NVIDIA GPU I have had has been reliable and efficient; whilst AMD GPUs are sometimes unreliable and can fail (from experience). Yes, NVIDIA GPUs tend to be expensive on the whole, but I personally think they are worth it.
Thanks for the feedback.
your welcome, wasn't sure about case and cooler so thought i'd ask, better to be safe than sorry.
are you going to use liquid cooling on your video card as well?
i might have waited until the new cpu's and sockets are out in July tbh, but if you can't wait, post some pics while your building it, so we can see how you get on etc :)
I could be wrong (8 Pack will probably be able to tell you for sure) but don't the R IV E motherboard have a few issues with Corsair Vengeance memory?
Hmmm, that's news to me. If that is so then I will swap the Corsair Vengeance RAM for the "TeamGroup Xtreem LV 16GB (2x8GB) DDR3 2133MHz Dual Channel Kit" RAM.
Well, I probably won't be building (and buying) this until the summer so I can always wait to see if the Haswell microarchitecture is released by then.
Anyway, yep I'll post pictures of the build when I'm doing it - looking forward to it already!
Dont go Vengeance with this build go any Hynix IC that goes 9-11-10 at 2133mhz. Team is a good one yeah. I use Team Hynix IC for a lot of my benching on RIVE.
Haswell is not going to outperform SB-E in multitasking and multi card environments.
Thanks for the advice!
its one thing spend 3k on new platform with headroom, but isnt the rumours that haswell-e with new socket will be coming out end this year. But then if your spending 3k on a pc perhaps value is neither here nor there compared to getting what you need now.
Oh, another question - I've heard that the Mayhems Tharssis Red Coolant can go a nasty colour and can also clog up in the tubing, could anybody confirm this? Is the "Mayhems X1 UV Red Premixed Watercooling Fluid 1L" better? Or is it just better to go for coolant that probably won't clog up the cooling system like "Mayhems Ultra Pure H20 Watercooling Fluid 1L"?
Thanks, will take a look at these components and keep that build in mind. Any reason for exchanging the V12 Watercooled Corsair Obsidian 800D for the BitFenix Shinobi XL FT Case with a different watercooling system, by the way?
Mainly the huge price difference.
The Shinobi XL is a big case, decent cable management for a neat build, it will take the 240mm rad of that closed loop water cooler in the roof easily.
The Antec Kuhler 1220 has sufficient cooling capacity to manage the heat from a 3930K even when overclocked.
Hopefully, IvyBridge-E will be released before I would like to start building this system too; but from what I've seen/heard, IB-E won't come until late this year, and I really want to start the build during the summer.
