- 28 Sep 2004
- westmidlands
Greetings...i've just built my new system ...and i've noticed the cpu is running at a higher temperature than i was expecting especially as i'm using a scythe ninja plus with the 120 fan it came with and arctic silver 5 ...using asus probe 2 it's reporting 58 / 59 c whilst running prime, in the bios maybe a few degrees higher ...not sure if it's the motherboard reporting the temps wrong or if it is not fitted correctly.
specs:
Motherboard Asus A8R32-MVP Deluxe flashed to 3.11 bios
Amd opteron 170 dual core running at 2.7ghz - vcore at 1.4
over volting on the motherboard disabled
Akasa acrylic uv case with 5 fans
Any advice would be appreciated ...as those temps are a little high for my liking.
Thanks in advance.
specs:
Thanks in advance.
