The 570 has more stream processors than the 560ti,
AMD might want to lodge a lawsuit on copyright infringement if Nvidia are now using stream processors.![]()
. gtx 570 all the way..
or like stated, why not go for the 6970??
IMAGE CROP FAIL![]()
I would go for the 6970, but I do some 3D stuff aswell as photoshop (main use is gaming, however). I thought (I might be/probably am wrong) that nvidia had a reputation for having a better performance when it comes to that kind of thing.
I'm pretty much settled on a 570 now, unless there are any major reasons I should go for the 6970.
Thanks for the help, by the way.
What would be the better out of those listed above if playing at a resolution of 1920x1200??
GTX 570
and also for games that require lots of vram like BF3 and more than likely MW3?
560ti
Thanks
If you can afford the 570 then I'd go for it (and consider a 6970). I've always been of the opinion of buying as much brute force as possible for your money when it comes to gfx cards![]()
In that case 460 SLI would be better as it has more brute force
If the programmed te op uses support cuda then an Nvidia card would be the best option![]()
