Hitatchi drive issue
25 Dec 2008
Birmingham
I have a Hitatchi HDS721010DLE630 1TB Sata hard drive. Occasionally it will lock up. It makes a sort of whir click repeatedly, a reboot fixes this. A temporary fix seems to be keeping it at a 45 degree angle.
Someone mentioned a firmware update being able to fix this issue? I didn't know you could update the firmware on drives? I have downloaded a program called Seagate tools for windows that has shown zero errors during it's test run.
It will run fine then whir click on constant loop. It does go away after a while, but renders the drive useless - it's like it's stuck momentarily. Drive is a little over 12 months old. It's totally random, works ok for a while then it plays up.
Any suggestions? I've tried changing Sata cable, operating system is Windows 8.
Thanks in advance.
1) Get the info you want to keep off it ASAP (i.e. back it up!)
2) Contact Hitachi to see if it is still in warranty
