Home Assistant beginners
My tablet in the hallway. The frame I had to print in two halves, still needs to be glued together and made to look better.
Looks great! I have seen ways to remove the seams, but I can't say I've ever tried!!
FYI - Hacs Add-ons don't automatically update (hadn't realised this). Just gone in and updated like 10 things.
So it looks like i cant run my refurbed laptop as a virtual machine as the vt-x has been disabled and i cant seem to find were to enable it in the bios… as i dont seem tp have virtualization technology in there, although its supportee by the laptop.
how else can i turn the laptop into a home asistant server??
You could run HA as bare metal install? Run it directly on the hardware.
Thanks for that dlockers…..but i have just found the HA windows app, that does everything i need and i will set that up tmrw.
also looking at those bios options, i know i dont have them on the laptop. I got it as a refurb from ebay and the bios is from 2011 and has no enable/disable functions on it. But its running windows 10 and it was cheap as chips.
The HA app should run on it, if not i will throw it in the bin lol
Super cool. What tablet?
Sorry missed this! It's just a Fire HD10, 9th gen I think. Running fire toolbox to debloat with fully kiosk browser, which allows HA integration for the tablet to control it. Such as adjusting the brightness for time of day, turning the screen off at night or whatever you want to do. It also uses the front facing camera for motion detection to wake the screen.
