- 17 Jan 2006
That's what I've got setup but I think it only checks the state of the thermostat at the time when the helper toggle is switched on, not continuously all the while the toggle is on doesn't it?
I’ve recently setup GivTCP in Home Assistant and batpred (battery prediction) which uses a dozen other tools (solar generation prediction, octopus rates, car cherging details) to predict the cheapest/most beneficial way to run your battery. It’ll charge during cheap slots (or hold if expecting loads of solar the next day) and export if there’s a high export rate e.g. if you’re on agile or there’s a saving session.Cool thanks, will look into it. Ideally want to do something that'll charge the batteries in the hour/2hour period that IO is activated. found a Mercedes integration last night so going to potentially look at that to say if it's charging outside of the IO period to start force charging the home Batteries too. Already got the 23:30-05:30 schedule in place for charging, but wil take a look at avoid battery drain option.
I am finding on Intelligent Octopus Go that when I plug the car into my Zappi (now integrated with IO) Octopus are giving me several extra hours a day off IO slots, ranging from mid morning to 7:30pm onwards.That's cool will take a look at that. Not so important for me this time of year. Filling the battery every night now with intelligent Go, and I get quite restricted solar output due to shading, and had no optimised charging during the day as only got a phev with a 12kwh battery so only needs about 1hr 45 to charge. But definitely something for the summer months when I move back to flux.
I use the "Octopus Intelligent Tariff" integration available for HomeAssistant via HACS. It is more extensive than the standard Octopus integration.@SBo how are you getting it to recognise when you're being given extra IO slots?
community.home-assistant.io
The go to is usually the fire tablet, either 8" or 10". Used with the fully kisok app it seems to work well. I've never mounted one, just used my fire 8" with this and worked fine.Can anyone recommend a cheap 10inch android tablet?
My old samsung tablet has totally died so looking for a cheap replacement as it will only be used for home assistant.
