Its good stuff.
Brew #2 was as follows for anyone interested.
Kit needed
demijohn / airlock / cider yeast / syphon / steriliser / nylon straining bag / funnel / blender / small saucepan / spoon
You can use a hydrometer to measure the original mavity & final mavity to judge strength & see whether fermentation is complete but I havent bothered so far.
Ingredients
> 4.5l pressed apple juice - not concentrate (I used Tescos the stuff in the fridges).
> 340g jar of Rainforest honey (Asda) - very dark and rich.
> 1 cooking apple
> 1 very strong cup of black tea for tannins made with 1-2 bags & left to stew.
Method
>Sterilise all gear according to instructions and rinse very well.
>Make tea & leave to stew & cool
>Melt honey in pan with apple juice over a low heat.
>Peel & blend up cooking apple with apple juice in a blender to a fine pulp (cooking apple adds acid). Add to demijohn.
>Pour in tea after removing teabags and add also honey mixture into the demijohn via funnel.
>Top up volume to 3 litres, do not fill!
>Wait for mixture to reach room temp and pitch yeast according to instructions.
>Shake really well to mix yeast in and aerate mixture.
>Add airlock with some water inside. Fermentation time can vary but the airlock should start moving fairly soon after. After a few days slowly top up juice over the next week so the brew doesnt climb out of the airlock.
>After around 2 weeks at normal room temperature (low 20s) the apple mash should fall out of the brew and the larger bits stay at the top. The airlock will slow right down to one bubble every few mins.
>Syphon out with straining bag over end of syphon to avoid picking up the apple mash. Bottle (sterilise these too - Grolsch flip tops work well) & add a dash of juice if you want it fizzy.
Leave for a month or so (longer the better really) and its good to go. You can drink it straight away but age definitely gives a better flavour. The resulting cider will be pretty dry and sharp - however you can always add a dash of apple juice to the glass and then pour for a sweeter drink.
The beauty is, you can experiment away with different flavoured juices (as long as 100% concentrate) and the same basics as above.
Enjoy.
