Sounds brilliant. Fingers crossed for them both for you. Did you sample the gluten free beer when you bottled it, and if so, how was it?
What kind of cost is involved in setting up a cornelius keg setup? Getting back into brewing, got my kettle, and mash tun sorted. Always fancied getting a keg and fridge but the money was too much back in the day. However, could be feasible now?
Eek, this is a big thread!
I'm looking to brew some beer for this summer. Thinking of trying a single hop american IPA or two to go with my BBQs. Where do I start?
Budget wise I'm happy to spend a few £100 if it gives more consistent results as I end up spending a lot on booze for my usual BBQs.
Didn't get a reply to this initially.. but can anyone help me with a set of kit to get me started? Figured I'd start with extract brewing. I was thinking of going with:
2 x 30L plastic fermenting bins with taps + syphon
hydrometer
paddle
sterilising kit
Not sure whether to go with bottles or kegs yet, I was thinking of doing a session IPA and maybe a punchier IPA as well so I'd probably want to chill it which makes me think bottles would be a better option.
For extract kits, I was going to go with something like:
http://www.brewuk.co.uk/single-hop-citra.html
http://www.brewuk.co.uk/mosiac-extract-recipe.html
hydrometer
paddle
sterilising kit
thats fine. i use a king keg and then lots of 1 ltr pets for storing them in boxes. i have another keg, the free one that i had but gave it to my mate to try a brew.
you need a large pan to boil the malt i see. i thought you might need a mash tin boiler.
i have your setup and make these type kits:
http://www.brewuk.co.uk/ab-amber-3kg-40pt.html
Personally I wouldn't bother with kits as a pale ale is very straight-forward to brew and you can do better/cheaper elsewhere. For each beer I'd start with with the following as your base malt:
http://www.themaltmiller.co.uk/index.php?_a=viewProd&productId=586
This is the cheapest price I have found for extract and assuming a 23 litre batch that should give you around a 4.5% beer which is a good place to be for a session ale. I assume your boil volume is a good bit less than 23 litres so you'll want your boil addition hops to have a high alpha content (Magnum or Warrior pellets would both be ok). Once you've diluted down in the fermenter you can dry hop (hop additions to the fermenter) with whatever takes your fancy... I think you mentioned you want to single-hop which I assume means to use just one type of hop (as opposed to a single hop addition) but for extract brewing, the hops that give decent bittering probably won't be great choices for dry hopping... Although I could be wrong.
For the 'punchier' IPA do you mean a higher alcohol content as opposed to a 'punchier hop taste'. If you mean a stronger brew then to the base malt listed above I'd add say an extra kg of pale dry malt extract and around 0.4kg of table sugar... The extra sugar should give you around a 7% beer while adding a bit of dryness which can compliment the beer nicely. 7% is also a good place to be in terms of not having to go too crazy with doing yeast starters etc. As for hop additions the same rules as above apply but more so with regards to utilisation in the boil as you have more sugar.
Choice of yeast and dry hops... Most things will work so it will come down to whether you want a more English or American IPA. I'm sure others can advise better than me or just do some googling.
As its your first brew I'd recommend going down the bottle route. 'Cooper's PET bottles' are a good choice and can be washed and reused. Keep the caps as well because even though the tamper seal will be broken they can be reused a number of times if you keep good care of them.
Since I'm pretty sure a new pot makes sense, is this OTT or a good bet? I think having a tap would be very useful and safes a lot of hassle:
http://www.brewuk.co.uk/32l-stainless-pan.html
I notice it doesn't say it can be used on an electric hob though which is a bit of a worry, that could make things difficult for me as my electric hob is a bit small
As i mentioned for extract you don't need to a pan bigger than 4-5L if using the method i linked, you may also run into issues getting a boil on some stove tops with bigger capacity pans.
Cool, sounds like that'll make life a lot easier! Having done some further reading that looks a lot easier method, is there any reason it's not the standard way of doing things?![]()
Also, I've got a syphon for checking gravity - the initial check seems OK but I realised using a syphon I would need to move the FV from where it's going to be sitting in order to get a proper reading, is this going to be a problem?
Finally, my main FV has a pre-drilled hole and came with a rubber grommet, but I didn't order an airlock. Should I just leave this hole open with the lid on with a damp, clean tea towel on top? Or should I stick the grommet in and leave the lid slightly off?
