The problem with most home or low end is people are paying lidl prices an expecting wait rose quality. If your property is that valuable to you spend at least £1500. Its not even the price of a top end telly!
It's better than nothing. Can't see most going to lengths with their house like you're protecting a bank. Especially annoying kids that chap your door then bolt.
Damn pricey for HD cameras. Would love that. Though I'd prefer it all rigged up to a DVR box.
EverFocus 2 MP HD-SDI IR Camera
Full HD CCTV Camera
EZH2036 - 2.0 megapixel full HDCCTV Weatherproof IR camera with progressive scan delivers 2 megapixel full HD 1080i quality digital images over standard coaxial cable. Wire new megapixel systems with familiar and easy to install coax and BNC connectors, or reuse the existing coax cable infrastructure to efficiently upgrade analogue systems to megapixel digital performance without the need to design and deploy an IP network. Enjoy true plug-and-play: each home run coaxial cable provides a full bandwidth dedicated communications path for the HD-SDI/HD-CCTV standards compliant signal; no addressing is required to capture full 1080i HD real time video, without congestion, latency or distortion.
The EZH2036 is based on a 1/2.8" 2 megapixel progressive scan sensor for full HD images, with field selectable choice of 1080i resolution output, or 720p resolution to conserve DVR hard disk space.
1/3" 2.1Megapixel CMOS Sensor
1080(1920x1080)@30fps
High resolution digital zoom (x64)
PIP(Full Image / Zoom Image)
Privacy Zone
OSD (On Screen Display)
DNR (Digital Noise Reduction, 2D+3D)
HLC (High Light Compensation)
HD-SDI/CVBS Output
2.8~11mm / F1.2 Varifocal Lens
Built in IR LEDs, RS-485 Port
DC12V
£299.95 (ex VAT at 20%)
Heh, desires.
