Home Cinema Speaker Recommendations
Permabanned
24 Jul 2016
South West
Hi Guy's. I've recently started acquiring bit's for my home cinema setup but need recommendations on either 2 rear surround speakers or 2 front surround speakers. I will prefer to save some money and buy second hand and keep the cost down without buying rubbish.
So far I have
Sony STR-DN1080 as a receiver
3 x Monitor Audio Radius 180's as left, right and center (but could possible use left and right for rears).
And a BK XXLS400 for the sub.
What do you think?
I don't fancy the idea of 45's they look too small to me plus people want stupid money for them. Smallest I'll go is 90's but I'm preferring the idea of getting some floor standers for the front and moving the 180's to the rear.
I have my eye on some Kef IQ5's or maybe some Monitor Audio Bronze BR5 if I can find a pair for the right money. Do you know of other similar speakers that will likely sell in the same ballpark as these?
S/h look at MA BX5
I'd be careful of mixing Kef and MA across the front sound stage. Also, IMO, Radius 180 would look odd as side/rear surrounds.
I've got MA rx all round.
Started with a 5.1 all in cheap package. Upgraded to bx then bit bullet for RX.
Package to BX was a bigger step than BX to RX
Ran RX fronts with BX rears for a while. But I would not mix brands
All second hand
Haven't heard anything anywhere near comparable to mine. So cant comment on comparison
I have a pair of these, a pair of the Bronze FX's, Bronze Centre and the Bronze W10 sub. The whole setup is cracking, but the BR5's really stand out, they're fantastic.
Well I’ve won some BR5’s so should pick them up tomorrow, will move the 180’s to the rear and maybe bi-amp the fronts. Will also upgrade the centre at some point.
What is the best way to set the BR5’s in bi-amp? What cross-over settings will I need to use ect?
I have the 45's as rears, surprisingly good.
My issue is not necessarily how well the will perform but how much people want for them.
The ones I seen went for not a lot less than I will be paying for the BR5’s and more than I paid for all 3 180’s.
To the OP, I have also this weekend bought and set up a Sony STR-DN1080. There are some hidden features you may have missed too!
Firstly, I replaced a five year old Yamaha RXV something 7.1 AV receiver as it was on HDMI 1.4, no 4K etc. And my word, this Sony sounds FAR better than the Yamaha with exactly the same speaker setup, and I was not anticipating that at all. Maybe expecting a little jump in quality as the Sony was 150 clams more expensive compared to when buying the Yamaha, but the details in sound, and control of the bass, its a different level.
Now then, I bet you missed this. The Sony has six HDMI inputs, all equal right? However, VIDEO 1 does not support UHD colours and is basically just for DVD players or old consoles, while the BD/DVD and SA-CD/CD are described in the manual as having "better sound" and should be used when connecting equipment for listening. Such a great technical term that is - "better sound" I can only guess that those two HDMI inputs go through some slightly better quality capacitors? The VIDEO 1 input thing is borderline false advertising as people could feasibly buy this thinking they can hook up six full UHD 4:4:4 colour video feeds.
Bi-Amp is a bit of a gimmick feature and waste of time with any receiver where all the power is being pulled from a single transformer.
I don't biamp mine.
It's worth it if you have two separate amps is four monoblocs or two stereo power amplifiers, or a 4 channel amp with 4 separate PSUs or windings or enough capacity power supply / storage caps so one channel isn't effected by another. I think the caps in my amp is 30,000 uf per channel
