- 20 Oct 2008
Unshielded (UTP) solid core Cat5e or Cat6. Make sure it's solid copper not Copper Clad Aluminium (if it's Excel it will be copper).
in what situation would the shielded cable be needed?
Work is well underway on the rewire and cat 6 install. I popped round this evening and noticed that he hasn't labelled up any of the cables.
Is there an easy way of checking which cable goes where before I connect them all to the patch panel? Would like it to be in a certain order![]()
If the cable has metre markers on it you should be able to work most of them out from that.
You'll want a cable tester anyway, and with it you'll be able to reliably trace all of them. Fully connect the faceplates in the rooms. At the patch panel end just punch down the blue pairs. With them all in you can work out what's what and then reconnect them where they should be.
