Home PC Upgrade Help
Am I alright going with the D3H then?
Its a decent board. It will do what you need. It just depends how far you want to go with things like clocking etc. It should manage 4.4ghz no problem. But if you were looking to have some head room and extra to push things then there are other boards that would do the job better. But for all round budget and performance the D3H is fine IMO. :D
Also, I think I'm gonna go Define R4. I really like the look of that case.
Its a nice case. And yes it looks like it will clearly house a H80i mate.
Forgot to mention im using the z87 mini itx board with the same CPU. Got 4.2ghz no problems , running very well. So sure the D3H would be at least similar to performance or better.
