Hi folks.
I'm looking to build a new PC that will run 24/7 for 20-40 VMware VMs.
The VMs themselves will only be used for HTML5 stuff on web browsers, so nothing too intensive. Will be 3gb RAM per VM.
The idea is that I'll remote into the server from my main PC so I can access the different VM's quickly.
I've built myself a parts list from some research but I'm fairly new to this stuff so want to run it by some more experienced people first.
I'm pretty sure this is already a bit overkill, but allows room for more VM's in the future if needed.
My main concern is the RAM. Someone else told me I'd be better off getting an ECC RAM kit rather than purchasing RAM separately, but I'm not sure if this is actually required for my needs? Was also told to get either 4 or 8 RAM sticks rather than 6.
The GPU is from a previous build as there's no others available for obvious reasons, but as I won't be gaming it should be fine anyway.
Appreciate any advice.
