you just need to up your multiplier in your BIOS, provided you have a good mobo
No, he needs to up his Front Side Bus, given that the chip will be locked for higher multipliers.
Sorry to butt in, I have an E2180 coming tomorrow with a P5K is it as simple as just upping the FSB for that to?
Currently running my E2180 8 x 400 = 3200Mhz. Had to up the vcore to 1.38 to get it stable. But only running on stock HSF, got a Vendetta coming soon, so maybe I'll be able to push it a bit further. Good chip.
I am newbie too, with a P5k and a e2180 and i want speed right here right now
If i go to the bios in my P5K and i change:
- multiplier to 8
- Vcore to 1.38
- fsb to 400
should it work?
If the fsb is going to be pumped up from 200 to 400. Would not that require to increase the board voltage?
How far can you push an E6600 on the stock cooler? I'm at 2.7 at the mo (just to check that I can oc correctly, and I believe its 34c). I assume I need something aftermarket to go to 3.3 or 3.6?
there's a guide stickied somewhere as to the specifics
edit:
http://forums.overclockers.co.uk/showthread.php?t=17612922
beginner's guide ^
http://forums.overclockers.co.uk/showthread.php?t=17803239
advanced guide ^
If you're gonna overclock, go buy a decent cooler lol.
As for the P5K - excellent mobos, only had mine a couple days and easily got up to 3.3Ghz on my Q6600. Just raised the FSB and upped Vcore a bit. Need to do more playing though, cos I think I can get away with a little less voltage, and tighten the memory timings. My PC5300 RAM working nicely at 1:1.![]()
As long as it doesnt limit your FSB, go for a higher fsb rather than tight timings.Thanks for the heads up pegasus, currently on 366x9 I think, timings at 5,5,5,15. Surely if they can be tightened even a little and remain stable - that would be better?
