OK, quick situation outline. This is happening on 3 seperate computers, at 3 seperate houses that I know of.
The internet stops working intermittently. The only way to get it back is to either power the modem off and on or do a hard reset. This happens if the modem is connected via USB, Ethernet or Ethernet to a router.
One thing I have noticed is that the frequency on the modem appears to be incorrect in all situations.
Telewest deny they have a problem, and it's a little difficult to get your point across when you're talking to India who are reading from a script.
What do I do? Anyone have a solution? Is it the modem or the line?
I can guarantee that the PCs are not at fault.
Thanks
Thanks
