Apart from the 12v coming out as 9v (mights be a hwmonitor issue), Id be a bit concerned with the temps considering the fans are at 100%, unless your on a stock cooler?
How does my system stand?
Also my RAM is only giving out a DRAM frequency of 798.3MHz -_- URGH!
Id definately find out the cause of the 12v rail issue.
I take it your monitoring it through CPU-z?
If so, it only reads half the rated speed.
Oh, okay i am little shaken with this know i should have done more research![]()
