How does ryzen boost work
17 Feb 2009
I have a ryzen 5 3600...
It says in the description it can " boost " to 4.2ghz however according to ryzen master I've never seen it get near that even with cinebench
3 Feb 2017
Mondas
The 3000 series is very fussy with boosting. Motherboard and cooling are very important. Make sure you have the latest motherboard bios and chipset drivers. That will give you half a chance. Make sure you have a well ventilated case aswell. You will not see 4.2 on all cores, only one core at a time. You will also need a half decent cpu cpu cooler.
OP
17 Feb 2009
Well ventilated case yes , good cooler yes ( noctua nh-u12s)
Definitely got the latest bios update
I'll double check later and post back a screen shot whilst doing a cinebench test.
OP
17 Feb 2009
Just ran cinebench and ya, one core will go upto about 4187mhz
