your room must be freezing.
would it not be more comfortable for you to just close the window?
the Q6600 is fine upto 80.C, so it is well below the max temp.
as my post above, just close the window and be nice and warm, the cpu will be fine
also dont forget to check for condensation, that will kill your pc.
