I think a fresh install of windows is needed!
About 90 seconds, but then I have steam run on boot up which slows things down.
run 'msconfig' from a command line, and start unticking the things you don't need from startup - that'll speed it up.
Can i then start a programme manually if it doesn't load at start-up?
I did that 4 weeks ago! I have Norton Anti-Virus installed which i think really slows things down!
On a cold boot it takes me 51 seconds (yes i timed it) from pressing the power button to Vista loading all my taskbar programs.
On start up i have Steam, X-Fire, Logitech setpoint and fraps loading.
Oh and thats with me entering my password aswell.
is your password "Supercalifragilisticexpialidocious" by any chance?
2 seconds or lower
set your computers to standby, if you have correctly setup sleep state S3 it means everything in your computer turns off apart from the ram. so it is using very little power.
then when you hit the keyboard, its almost instantly on, best bit is you can stndby and everything on your screen stays there. for example you could have 10 web pages and a excel sheet up, go to standby and come back in two hours, hit the keyboard and its all back up
