- 29 Jul 2023
- Ipswich
I want to use the machine at other peoples housesIf it's single phase you don't need an inverter or transformer to run it off the single phase domestic supply.
But you do need the socket to be rated for supplying 7kw+ and the cable going back to the consumer unit to be rated for 7kw+ and the fuse/rcd to not trip with whatever peak the pressure washer draws. Easy work for an electrician.
If you're not able to get proper wiring done for it then get a pressure washer up to 3kw which comes with a domestic plug attached.
