Well I have got a plan to install addressable LED strips all the way along the roofline once it's done......... the neighbours are going to love me at Christmas and Halloween........ and hate me all the rest of the time.....
IndeedHaha, RGB solar panels, you'd be on to a winner with that one, some neighbors might object of you have them, and not sure on the planning regs either.
Yeah. I am going to wait for subsidies from the government before going solar and battery.Just don't look to replace a gas boiler with electric, probably a better swap from gas yet zero grants and ridiculous costs to install as i have been finding (and that ignores the runnings costs). but its ok. we can just use grants for cars which take years to get co2 benefit. ASHP no good either as its a flat and it needs hot water
Isn't the issue with the heatpump, that you need to pay a lot upfront them jump through hoops to get it back. I also thinks there's an issue with the design from what some people say, I.e. older houses need new rads and stuff like that.Indeed
Our boiler is due replacement in a couple of years and I would go for something like heatpump if the price was right. But the subsidies on those as I recall are not good enough. I mean I would have to get my windows replaced too if I went in that direction which are also bloody expensive.
Yea. That’s why I did not rush into anything. Unless my boiler pops unexpectedly I plan on getting another 2-3 years out of it. But it is a good 12-15 years old from what I can see so not very efficient.Isn't the issue with the heatpump, that you need to pay a lot upfront them jump through hoops to get it back. I also thinks there's an issue with the design from what some people say, I.e. older houses need new rads and stuff like that.
Yip, wait until next year for proper high temp heat pumps. Just swap with gas boiler, none of the lukewarm, insulate everything nonsense!
https://group.vattenfall.com/uk/new...hes-heat-pump-solution-to-replace-gas-boilers
