- 10 Oct 2006
I pay £20 at a local tyre fitter for a 19" wheel or £15 for 18" and under but they never mark a wheel and balance perfectly first time so I think it is money well spent.
This is worth it's weight in gold. There is almost no limit to what I'd pay for tyre fitting with this guarantee, the amount of times I've had wheels not quite right but not bad enough to be obviously wrong is depressing.
after having read through this older balancing thread https://www.honestjohn.co.uk/forum/post/index.htm?t=53904
look like accurate balance could be 0.1g tolerance and 5g normally, they suggest alloy rims may have difficulty for accurate weight positioning,
and two resonant frequencies/speeds where you could see vibration .. will check out if the balancing machine is a Hunter (like the f1as alignment machines are)
they have to make money or theres no reason to be in business. as said you can look after regular customers if their having other work done but to work for next to nothing or cash /tea money doesnt pay the overheads.In anything but a small indie garage the people taking your wheels off and changing tyres etc are salaried.
The only actual cost to the company is a few pence in wheel weights and a valve.
