marscay said:you shouldn't be using enough water that it's a problem anyway.
You dont need to use any water.
Gashman said:do all you people waste all this time lapping by hand, why not use a dremel or something?![]()
Mr Footlong said:LMAO, let me know how that one works out for you!![]()
Mr Footlong said:Personally I wouldn't dream of lapping without water. It helps to move the sanded debris out of the way, allowing for a smoother finish. I could never, ever get as good a finish doing it dry. Tried it once on a disused IHS and the results were poor in comparison imo.
marscay said:i agree completely, although i didn't go to your lengths sealing with electrical tape.....just used that piece of black plastic that the chip came in.
Mr Footlong said:Me=Virgo=Perfectionist and then some sadly. Yeah it takes me an hour-90 mins on avg depending on just how good a finish I want. Having a glass table in the living room helps a lot.
Umm, what they were getting at before is that a Dremel wouldn't work. The whole idea is to sand it flat using a flat surface. I struggle to think of a way a Dremel might possibly even begin to work.Gashman said:and how long would it take with a dremel?![]()
BillytheImpaler said:Umm, what they were getting at before is that a Dremel wouldn't work. The whole idea is to sand it flat using a flat surface. I struggle to think of a way a Dremel might possibly even begin to work.
Though it would be amusing to read about you destroying a CPU through ignorance, I'm a nice guy.![]()
You need to do some research into the procedure. You don't want it to be fast, you want it to work well. It's not like sanding some piece of wood, you're trying to put a mirror finish on a piece of nickel plated copper. Research polishing methods used in industry. They are similar in scope to the simple lapping methods overclockers use.Gashman said:ok what about something better, like a belt sander? not planning on lapping, just wondering if theres a better way to do it than sitting for ages rubbing it with sand paper, which sounds pretty inaccurate as well...
BillytheImpaler said:You need to do some research into the procedure. You don't want it to be fast, you want it to work well. It's not like sanding some piece of wood, you're trying to put a mirror finish on a piece of nickel plated copper. Research polishing methods used in industry. They are similar in scope to the simple lapping methods overclockers use.
