I have a two zone heating system.Why 2 thermostats?
Im looking at some inline smart switches and wondered if anyone has any of the Sonoff ones? Ive read mixed reports from them working great to burning down your house in an instant due to them being made in China. Ive also read about them not having an earth which I know isnt ideal but can look to add that in if need be.
Are there any others that are worth looking at? Im looking to power some lamps and some LED strip as well as possibly a water feature for the garden (will be in a suitable IP box but need to test wifi signal etc first).
Thanks
Why does a smoke/carbon monoxide detector have to be smart, in this case the Nest device, at around £85, that just seems bonkers.
Yeah the price is pretty daft but they're good if you have any Nest cameras. Whenever mine goes off it pulls up a snapshot of all my cameras and saves a recording so I can see what's going on and go back to it to see what's happened. You can turn it off from your phone too which is helpful if you're good at burning food like I am. I only have one because I found it reduced from $125 to $30.Why does a smoke/carbon monoxide detector have to be smart, in this case the Nest device, at around £85, that just seems bonkers.
Thanks
I have no smart home technology and don't want any!
It drives me up the wall when I visit people and they sit about barking orders to some gadget which can't understand them in a vain attempt to do mundane things like adjusting the temperature by 1 degree or dimming a light. Just get off your backside and do it yourself!
Do you feel the same about things like dishwashers or washing machines?Nothing, because none of it justifes the premium. Pretty much all of it falls under "solution in search of a problem". I don't have smart lights because I have hands that work. I can see that they might be useful to disabled people though. I don't need a smart thermostat because it's not really any better than a dumb one. Etc. And that's before we get onto the woeful security or every smart gadget. Or smart locks that can be bricked by the manufacturer without you knowing. For example.
My smart thermostats save me a lot of money each month. My smart cameras let me keep an eye on things around the house when I’m not there. A lot of it is so I don’t have to get up when I’m watching TV, yeah. It’s nice that all my lights turn on at sunset, it’s nice that I can dim them when I put a movie on, it’s nice that I can see if I’ve left any lights on or the garage open and then turn them off or close it.
But yes, the one in my office is because I’m lazy and cant be bothered to get up to turn on or off the light![]()
That is an interesting statement, as I have heard from very many people who have moved over to smart thermostats, that it actually increases costs, because they are far more adjustable, and far easier to adjust, (via app), they find they use the heating far more than they used to prior so costs actually go up.
We definitely change ours more than we did with the dumb thermostats but the weather where I am means I usually have AC or heat running all the time anyway and the Nest thermostats have features built in to make that a lot more efficient. Our bills are considerably cheaper than our neighbours who have almost identical houses.That is an interesting statement, as I have heard from very many people who have moved over to smart thermostats, that it actually increases costs, because they are far more adjustable, and far easier to adjust, (via app), they find they use the heating far more than they used to prior so costs actually go up.
