What's the cross-app support like for smart devices though, i've specced up a lot of things to buy for our new place, but i'm still worried about having to have 10 different apps to control each thing.
I also wonder what the easiest way of making something smart is, for example a table lamp can be made smart in 3 ways:
- A smart wall socket with a normal lamp plugged in
- A smart plug adapter, which sits between a normal wall socket and a normal lamp
- A smart bulb, which can also use a normal wall socket
Here's a few things i've planned:
- Nest thermostat
- Nest smoke/carbon monoxide alarm
- Nest doorbell
- Hue bulbs for ceiling lights
- LightwaveRF sockets OR tplink plugs for table/floor lamps
- mySmartBlinds for remote/scheduled blind automation
- Motion sensors (probably samsung smarthings) in kitchen/hallway
- Loop electricity and gas monitor
- Cameras/Security system
And some things that would be nice if the prices weren't extreme:
- GROHE water guard
- Smart washing machine
- Smart dishwasher
- Smart oven
ok.. what do you mean with cross app support?
Ideally I would say you set it all up and then control with voice assistants.. I almost never have to use the apps, I tried bluetooth bulbs forever ago and that scared me off apps forever.. you need it to be more seamless than that.
On your lamp question.. I'd say bulbs (in fact I'd more than say it, I've done it) because if you're using hue you need a hue hub, so thats one hub you absolutely need. If you want to go with smart sockets then you'll need something like a lightwave hub and socket which is a lot more expense and more complexity to replace the functionalist of just another hue bulb.
Similar although not quite as complicated with the smart plug but again it adds bulk and potentially another hub.
Plus with anything other than bulbs you lose all the dimming functionality.. so thats simple to me, stick with just bulbs.
On your plan I'd say:
- Nest thermostat - sensible but consider hive or tado
- Nest smoke/carbon monoxide alarm - sensible
- Nest doorbell - is that available in the UK yet? Consider ring, with amazon ownership it's now super cheap and well backed
- Hue bulbs for ceiling lights - no brainer
- LightwaveRF sockets OR tplink plugs for table/floor lamps - why not bulbs? I don't understand why you'd treat lamps differently to ceiling lamps.. if it's cost, look at INNR on Amazon, you can get B22.E27/E14 and GU10 which covers pretty much every option
- mySmartBlinds for remote/scheduled blind automation - know nothing about blinds
- Motion sensors (probably samsung smarthings) in kitchen/hallway - sensible.. you can get compatible xiaomi sensors cheap too
- Loop electricity and gas monitor - no idea what this is
- Cameras/Security system - could sit well with nest
but then the rest of it... why?
I have a smart dishwasher and it is utterly pointless, I can turn it on from a distance and get alerts about salt and rinse aid but I can't do anything about it until I'm in front of it so I find the whole thing a total gimmick.
Having invested fairly heavily and (disclosure I guess) working partly in the field I would say heat, light, entertainment.. all suit it very well but there is a lot of smart home snake oil out there.. think about what you want to achieve and whether it's worth the premium.
