I install HA as a VM using HAOS. You get more flexibility and control that way. Otherwise, crack on!
Cheers, i need to do lots of youtube watching i think!
You can do best of both - I can control independently through Hue Hub or HA. It integrates so seamlessly it is childs play (and useful to have both options available IMHO).Cheers, i use Hue too, although with needing a lot of new bulbs, it made sense to give the option for a wider range without being tied into Hue. Especially for sensors etc.
Getting fairly excited to start on this. We move into a new rental on the 3rd and so can dig out my old Hue bulbs and start to slowly get things configured. Is a raspberry pi still the preferred route? I saw this which seemed recommended
Home Assistant Yellow
Home Assistant Yellow is your Matter-ready, upgradeable, and extendable smart home hub. You won't need anything else.www.home-assistant.io
Or is it worth getting an Intel NUC type device?
Benefit of the Pi is that i've already got one running Volumio for music and so i figured i could buy a double case to keep things neater.
Lewis who runs EverythingSmartHome is a really good bloke, sells his own design presence sendor, does Youtube videos and has a Discord channel if you want advice.
Cheers, been watching some of his videos, really useful and doesn't seem annoying either.
Currently trying to weigh up whether it's worth trying to start this now in the new rental, or if it makes more sense just waiting till our house is built.
Arguments for starting now
-It's fun
-Great practice/learning experience whilst only have a few devices
-Get some basic automation in the rental for ~10 months
-Gets devices on the network i'll be carrying over and in theory room choice should be similar (lounge will still be lounge for example)
Arguments against
-Up front spend on stuff i probably don't need to be spending money on
-Might be a ballache trying to unpick things when we move
The last against is probably the main one. However i guess i could always just start from scratch and i wouldn't be in any worse position.
It's not a black hole, it's a "bottomless pit of opportunity"Yeah, think i'm definitely leaning to starting now. My main concern is the black hole of "things" i then start to buy![]()
can you re-deploy an old laptop to learn about HA ..Currently trying to weigh up whether it's worth trying to start this now in the new rental, or if it makes more sense just waiting till our house is built.
Agree except Hue has really nailed basic automation which is all most folk need anyway.HA is far better for automation than a proprietary hub. HA allows automation locally with devices from any manufacturer across a variety of protocols. It’s extremely flexible and it is not difficult to set up basic or even advanced automations to suit your needs. From a personal perspective, it’s also easier to set up automations using a browser on a PC than try to do so on a mobile app.
But only if you use the Hue ecosystem which is expensive and limitedAgree except Hue has really nailed basic automation which is all most folk need anyway.
Yeah but it's great and works, and it is fully compatible with HABut only if you use the Hue ecosystem which is expensive and limited
Why bother with HA if you do everything within Hue?Yeah but it's great and works, and it is fully compatible with HA
I am tempted to just buy a HA Yellow. I seem to be getting far worse bluetooth coverage compared to an RPi...
