I fear it's only the start....Big Chris said:Too late...
dave2k2005 said:I just want the bicep/tricep/chest being done, because I just want to get a bit built in the arms.
dave2k2005 said:Also, if I use my dumbells to weight lift, will it stump my growth?
GordyR said:To get larger arms you need to put weight on all over your body. You can't just do hundreds of bicep curls and expect your arms to get huge.
Absolutely not. The whole growth stunting thing is an age old myth.
GordyR said:Absolutely not. The whole growth stunting thing is an age old myth.
A.N.Other said:I think that might be pushing it a bit far tbh for someone just starting out - remember he's 15! I wouldn't consider myself particularly unfit (I do row and things) but I would die if I did that. People's bodies are very different.
Mr_White said:Not at all, if he does it in sets he can cope with any time throughout the day, he'll notice a difference.
A young lad should be able to cope with at least 10 a set.
I'm 6', weigh just under 12 stone and my biceps are smaller than the underlying arm... yet I can do 10 full rep fingertip chin-ups from a door framedave2k2005 said:I'm not really looking for huge arms, more for strength, but it's pretty much the same for both, right?
dave2k2005 said:I can do 10 press ups quite easily at a time. So what you're trying to say is do 10 press ups at 10 different times throughout the day?
dave2k2005 said:btw guys,
Is there anything I can use to increase the strength in my wrists? Theres something thats always been odd with my wrists and they kill after I do weights/if I lift heavy objects.
Amp34 said:Oh you can! It was great fun watching all those body builders with massive tops and tiny snooker cue legs training on the freeweights. The only reason I went to work.
Mr_White said:Start of simple and easy, I wouldn't start messing your diet about at this stage.
Just do say, a hundred push ups a day, in sets of 20, or 10 if you can't manage 20 in a row yet.
do that every day and you'll notice a difference within a few weeks, although you will most likely be quite sore since you're not used to the lactic acid.
mattbrown91 said:I am similarly 15 well, nearly 16...anyway, less of that.
I do a similar thing, interspersed with situps and a couple of 10 kilo weights.
Would I be better off dropping the weights or pressups or keep them both ?
I also regularly go on runs, sprint frequently and play football.
Matt
